AdcontactAdcontact
Cart
0
You have no items in your shopping cart.
Compare
(0)
You have no items to compare.
  • Account
  • Wishlist
  • Log In
  • Sign Up
Menu
  • Webshop
    • Industrial Components
      • Heat Shrink Tubing
        • HongShang
          • Thin Wall Tubing
            • HB-1
            • H-2F(YG)(3X)
            • Flexible / 2:1 / for flexible gas pipes / HBG
            • Flexible / flame retardant / 2:1 / low shrink temperature / H-2(LS)
            • Yellow/green striped / flexible / flame retardant / 2:1/3:1 / mil spec 135 degrees / H-2F(Y/G)
            • Flexible / flame retardant / 4:1 / mil spec 135 degrees / H-2F(4X)
            • Flexible / flame retardant / 3:1 / mil spec 135 degrees / H-2F(3X)
            • Flexible / flame retardant / 2:1 / mil spec 135 degrees / H-2F
            • H-2R
            • Flexible / flame retardant / 2:1 / halogen free / H-2(HF)
            • H-2(CB)
            • Flexible / flame retardant / 3:1 / H-2(3X)
            • Flexible / flame retardant / 2:1 / H-2(Z)
            • Non flame retardant / 2:1 / H-1
          • Dual Wall Tubing
            • H-5(2000)
            • HBK
            • H-5(3X)-M
            • H-5(3X)-F / H-5(4X)-F
            • H-5(3X) / H-5(4X)/H-5(2X)
          • Special Products
            • HFSP
            • H-2(XT)/H-2(XT)HF
            • HTFE
            • H-200E/H-200E(TW)
            • HDR/HDR(TW)
            • H-175K
            • H-150K
          • Selection Table Heat Shrink Tubing
        • DSG
          • Single Wall
            • Deray-H
          • Dual Wall
          • Medium Heavy Wall
          • Specialty Non-Polyolefin
          • Automotive
          • Canuflex - Braided Sleeves
          • Electrical & Utilities Products
      • Connectors
        • Deutsch Connectors
          • Connectors
          • Accessories
          • Contacts
          • Tools
        • TE Connectivity
        • Stocko
          • Stocko Connectors, Connector Systems
            • PITCH 2.5 MM
            • PITCH 2.54 MM
            • PITCH 3.5 MM
            • PITCH 4.2 MM Connector
            • PITCH 5 MM
            • PITCH 5.08 MM
            • PITCH 5.08/7.62 MM
            • PITCH 6.35 MM
            • PITCH 6.5 MM
            • PITCH 8 MM
            • PITCH 11.4 MM
            • PLUGS
            • PIN STRIPS
            • PCCR
          • Crimp Contacts
            • Receptacles
              • 2.8 MM
              • 4.8 MM
              • 6.3 MM
            • Tabs
              • 2.8 MM/ 4.8 MM/ 6.3 MM
              • 6.3 MM for fixing
              • 6.3 MM weld Tabs
              • 4.8 MM for fixing and welding
            • Printed boards contacts
            • Open barrel terminals
              • Without insulation chrimp
              • With insulation crimp
              • Special types
              • C - Type
            • Special connectors
            • End splices
            • Sockets
            • Circular pins
          • Housing
            • Standard
            • Self-locking 4.8 mm
            • 6.3 mm
            • Multi-way 6.3 mm
            • Multi-way self-locking 2.8 - 6.3 mm
            • Multi-way self-locking 6.3 mm
          • Solderless Terminals
            • Solderless terminals
              • non insulated
              • pre insulated
            • Pin terminals
            • Parallel splices
            • Butt splices
            • Receptacles
            • Tabs
            • Sockets / Plugs
        • Vogt
          • Riveting technique / Mechanical elements
              • Blind rivets
                • flat head DIN 7337 A, *excepted
                • flat head DIN 7337 A bargin sales
                • countersunk head DIN 7337 B, *excepted
              • Blind rivet nuts
              • Flaning full rivets
                • mushroom head DIN 6791,, *excepted
                • flat head DIN 7338 *excepted
              • Hollow rivets
              • Tubular rivets
                • DIN 7340 A, * excepted Ø 0,8 - 1,9
                • DIN 7340 A, * excepted Ø 2,0 - 2,4
                • DIN 7340 A, * excepted Ø 2,5 - 3,0
                • DIN 7340 A, * excepted Ø 3,1 - 16
                • DIN 7340 B, * excepted Ø 0,8 - 1,9
                • DIN 7340 B, * excepted Ø 2,0 - 2,4
                • DIN 7340 B, * excepted Ø 2,5 - 3,0
                • DIN 7340 B, * excepted Ø 3,1 - 16
                • form C
                • form D
              • Rivets
                • rivets with snap head DIN660, *excepted
                • riv.w.countersunk head DIN 661, *excepted
                • rivets w.flat round head DIN674, *excepted
            • Spacer
              • Spacers brass nickelplated
                • Internal thread
                • with internal thread on both sides
                • with internal and external thread
              • Spacer steel zinc-plated
                • Internal thread
                • spacers UNC 4-40
              • Insulating spacers
                • with external thread on both sides
                • snap in form with external thread
                • snap in form with internal thread
                • snap in form with head
                • snap-in
                • with internal and external metal thread
                • with threaded-end rod of metal
                • cap nut with internal metal thread
                • cap bolt with external metal thread
              • crimping sleeves Ø 0,1 - 4,9 mm
              • crimping sleeves Ø 5 - 10 mm
              • crimping sleeves Ø 10 - 20 mm
              • cylindrical tubular pces
              • cylindrical tubular pces Ø 2,5 - 21
              • spacer sleeves metal Ø 1,0 - 5,9
              • spacer sleeves metal Ø 6,0 - 18
              • Cable clips
                • 1 mounting hole
                • 2 mounting hole
                • Special cable clips
              • Clamping disks
                • Connecting disks
                • Clamping disks
                • Clamping straps
                • Clamping straps
                • Fastening angle
              • Washers Ø 0,4 - 3,2
              • Washers Ø 3,3 - 5,9
              • Washers Ø 6,0 - 50,0
              • ornamental head
          • Contact pieces for PCB / Soldering tags
            • Soldering parts for PCB
              • Soldering lugs for PCB
                • For hole < 1.3mm
                • For hole = 1.3mm
                • For hole > 1.3mm
                • Special soldering lugs
                • In chain form
                • Soldering lug bars
                • IDC contacts
              • Contact parts
              • Eyelet tags
              • Small stamping parts
              • Fuse holders
                • Diameter 5mm
                • Diameter 6.3mm
                • Diameter 8.5mm
                • Quartz holders
              • Contact caps
              • Wire-Wrap-Pins
                • From Wire
                • From Wire, bent
                • Stamped
                • Receptacles for Wrap-Pins
              • Headers
                • Single Row
                • Single Row Angled
                • Double Row
                • Headers
                • Angle Pin Headers
                • Angle Pin Headers Tapeform
              • In bulk
              • PCB Spring contacts
              • Contacts to push-on
              • Soldering bridges
                • Jumpers for PCB
                • Insulated Jumpers
                • Bridge Connectors
                • Tag Blocks
              • R.C.B terminal blocks
            • SMD Stampings
            • Tubular - and turned parts for PCB
              • Seamless plugs soldering tags Collar sleeves
                • Collar Sleeves
                • Double Collar Sleeve
                • Seamless plug pins
                • Rolled / Stamped
                • Seamless de tube
                • Special
              • Connecting eyelets f. PCB
              • Plug pins from wire Contact parts
              • Electro-stamping parts
              • Lamp holders
              • I.C. Sockets
              • Battery terminals
              • Battery contacts
            • Soldering tags
              • Soldering tags, 1 tag
              • Soldering tags, 2 tags
              • Soldering tags, multi tags
              • Soldering tags special
              • Eyelet tags, 1 tag
              • Eyelet tags, multi tags
              • In bulk
            • Mounting tabs and for PCB
              • Dimension nominally 2.8 mm
                • 1 foot
                • 2 feet
                • bent
                • receptacles
                • Press-in technology
              • Dimension nominally 4.8 mm
                • flat
                • bent
                • receptacles
              • Dimension nominally 6.3 mm
                • flat
                • bent
                • receptacles
                • Press-fit technology
              • Dimension nominally 9.5 mm
              • Tab blocks for PCB
                • grid 5 mm
                • grid 10 mm
                • angled, grid 5 mm
                • tab blocks ABB
                • insulated cup washers
            • Soldering parts for PCB reflow
          • Cable terminals / Solderless splices
            • Tabs screwable and weldable
            • Flat- and round connectors
              • Receptacles and tabs 2.8 mm
                • DIN 46247 / part 1
                • DIN 46340 / part 1
                • rolled
                • bent
              • multi connectors 2.8 mm
              • Receptacles and tabs insulated 2.8 mm
                • part. insul. PVC DIN 46245 part 1 with extra support-sleeve
                • part. insul. without extra support-sleeve
                • insul. PA with extra support-sleeve
                • insul. PA without extra support-sleeve
              • Receptacles and tabs 4.8 mm
                • DIN 46247 / part 2
                • bent
                • tabs
                • Posilock
                • with snap-in tongue
              • multi connectors 4.8 mm
              • Receptacles and tabs insulated 4.8 mm
                • part. insul. PVC DIN 46245 part 2 with extra support-sleeve
                • insul. PVC with extra support-sleeve
                • insul. PVC without extra support-sleeve
                • part. insul. with extra support-sleeve
                • insul. PA bent sithout extra support-sleeve
              • Receptacles for pins in chain form 4.8 mm
                • receptacles for pins in chain form un-insulated DIN 46247 part 2
                • multi-connector in chain form un-insulated
                • receptacles for pin in chain form part. insulated PVC
                • receptacles for pins in chain form insulated PA
                • tabs in chain form un-insulated
              • Receptaclesa dn tabs 6.3 mm
                • DIN 46347 / part 3
                • DIN 46340 / part 3
                • rolled
                • tabs DIN 46248 part 3
                • bent
                • screwable
              • multi connectors 6.3 mm
              • Receptacles insulated 6.3 mm
                • part. insul. PVC DIN 46245 part 3 with extra support-sleeve
                • part. insul. heat shrinkable with extra support-sleeve
                • insul. heat shrinkable with extra support-sleeve
                • insul. PA heat shrinkable without extra support-sleeve
                • multi-connector part insul. PVC with extra support-sleeve
                • multi-connector part insul. PVC without extra support-sleeve
              • Receptacles for pins in chain form 6.3 mm
                • receptacles for pins in chain form un-insulated DIN 46247 part 3
                • receptacles for pins in chain form bent un-insulated
                • tabs in chain form part. insulated PVC
                • receptacles for pins in chain form part. insulated PVC.
              • housings for tabs
                • Dimension 2.8 mm
                • Dimension 2.8 mm
                • Dimension 6.3 mm
                • special
                • housings
              • receptacles 7.7 mm
              • receptacles 9.5 mm
              • Receptacles insulated 9,5 mm
              • branch terminals IDC
              • pin connectors insulated
                • receptacles for pins insul. PVC with extra support-sleeve
                • receptcles for pin insul. PVC without extra support-sleeve
                • plug part. insul. PVC with extra support-sleeve
                • plug part. insul. PVC without extra support-sleeve
              • Pin connectors and round receptacles un-insulated
                • plug pins form A
                • plug pins form B
                • plug pins
                • Chainform
              • heat-shrinkable sleeves
            • end-sleeves
              • copper DIN 46228/1 0,1 - 2,5 mm² *excepted
              • copper DIN 46228/1 4,0 - 95 mm² *excepted
              • copper DIN 46228/1 120 - 150 mm² *excepted
              • from brass 0,1 - 4,0 mm²
              • from brass 6,0 - 150 mm²
              • clips
                • in bulk DIN 46225 part 2
                • chain
              • boxes end splices un-insulated
              • cable eyelets
            • end-sleeves insulated
              • end-sleeves insulated with PP
                • DIN 46228/4 colors, *excepted
                • F colors
                • D colors
                • boxes end splices insulated
              • end-sleeves chainform with PP
                • DIN 46228/4 colors stripes
                • F colors stripes
                • D colors stripes
                • F colors chain
                • D colors chain
              • twincable sleeves with PP
                • F colors
                • D colors
              • end-sleeves for short circuit proof and earth fault current with PA
            • Cable terminals
              • solderless terminals
                • ring DIN 46234, *excepted
                • fork
                • ring, 3-way
                • ring 4-way
                • set terminals uninsulated
              • solderless terminals insulated
                • ring PVC DIN 46237, *excepted
                • ring PA DIN 46237, * excepted
                • ring heatshrinkable
                • fork PVC
                • fork PA
                • fork heatshrinkable
                • ring, insulated PVC 4-way
                • ring, insulated PVC 3-way
                • set terminals with insulation
              • soldering terminals, open
                • ring form A
                • ring form B
                • fork form A
                • fork form B
                • hook
                • telephone DIN 46257
                • long hole
              • Soldering terminals, rolled
                • ring DIN 46211, *excepted
                • ring
                • fork DIN 46211, * excepted
                • fork
                • hook
              • crimp terminals
                • in bulk DIN 46225
                • in chain form DIN 46225
              • Tubular terminals
                • flat
                • bent 90°
                • tight plate
              • flat with insul.
              • parallel connectors
              • Butt-splices insulated
              • butt-splices, un-insulated
              • reducing butt-splices un-insulated
              • pin connectors
                • pin round DIN 46230, *excepted
                • pin flat DIN 46230, * excepted
                • pin round PVC DIN 46231, *excepted
                • pin round PA DIN 46231, *excepted
              • connector in PA
            • Boxes and sets
              • set with tool
              • set without tool
                • set without tool
              • bag for replenishment
              • box/set
            • chain
              • F colors chain
              • D colors chain
              • ring PVC
              • Ring PA
              • fork PVC
              • pin round
              • Receptacles for pins in chain form 2.8 mm
                • receptacles for pins in chain form un-insulated DIN 46247 part 1
            • tab bloc with blind rivet
              • 1-pole 95°
              • 2-pole 95°
              • 4-pole 95°
          • Hand tools / Presses and accessories
            • Hand tools
              • Striker spring press
                • ransition piece for tips from presses
              • Tools for wiring
                • wire stripper
                • tool
              • Hand riveting tools
                • for blind rivets
                • for blind rivets nuts
                • for tubular rivets
                • for cable eyelets
              • push on tool f.recept.
              • Crimping tools eco-line
                • for un-insulated terminals
                • for insulated terminals
                • for receptacles for pins bent
                • for terminals
                • for terminals bent
                • for end ferrules
                • Interchangeable dies
              • Crimping tolls professional-line
                • for terminals
                • MCT Mobile Crimping Tool
              • Manual air press
                • press head
                • press head with exchangeable dies
                • spare parts for air press
                • accessories for manual air press
              • Battery device
              • Hand-tools for ferrules
                • for parts in bulk, Eco-Line
                • for parts in bulk, Profi-Line
                • for stripes
              • Shrink apparatus
              • Bargain sales hand tools
            • Presses
              • Inserting devices
                • applicator
                • spare parts
                • accessories
              • Riveting tools
                • Inserts
                • pick-up attachment
              • Manual presses
                • Connecting eyelets f. PCB presses
                • manual riveting press
                • Manual presses
                • Lever presses
              • Pneumatic presses
                • press
                • tandem cylinder
                • Pneumatic gang
                • Bargain sales pneumatic presses
              • Machines
                • strip and twist machine
                • stripper-crimper
                • electr.auto crimp.machine
                • Manual air press
                • Bargain sales machines
              • accessories for presses
                • press body
                • lengthening for throat
                • scanning spot
                • Bargain sales accessories for presses
                • Spare parts for press
        • HTP
          • M8 Circular Connectors
            • Field Attachable
              • Female field attachable with screw contacts
              • Field Attachable with soldered contacts
              • Male field attachable with screw contacts
              • Male field attachable with soldered contacts
            • Moulded Cable
              • PVC o PUR moulded cable
              • Totally shielded with PVC or PUR shielded cable
              • With PNP or NPN Led and PVC o PUR moulded cable
            • Panel mounting
              • Female panel mounting with wires
              • Male panel mounting with wires
              • Female panel mounting with soldered contacts
              • Male panel mounting with soldered contacts
              • Female panel mounting for PCB
              • Male panel mounting for PCB
              • Panel mounting adapter
            • T Connectors
              • T Connectors
            • Snap
              • Female Snap
              • Male Snap
            • Field attachable ATEX
              • Field attachable with screw contacts
              • Field attachable with soldered contacts
          • M9 Circular Connectors
            • Moulded Cable
              • Female Moulded Cable
              • Male Moulded Cable
          • M12 Circular Connectors
            • A-Coded
              • Field Attachable
              • Moulded Cable
              • Panel mounting
              • T-Splitter Connectors
            • B-Coded
              • Field Attachable
              • Moulded Cable
              • Panel mounting
            • C-Coded
              • Moulded Cable
              • Panel mounting
            • D-Coded
              • Field Attachable
              • Panel mounting
            • S-Coded
              • Moulded Cable
              • Panel mounting
            • T-Coded
              • Moulded Cable
              • Panel mounting
            • X-Coded
              • Panel mounting
              • Moulded Cable
          • M23 Circular Connectors
            • Panel mounting
              • With contacts for PCB
            • Moulded Cable
          • EN 175301-803 (ex DIN 43650)
            • A/ISO 4400
              • Field Attachable
              • Field attachable with electronic components
              • Moulded Cable
              • Moulded Cable with electronic components
              • Base type A 28,4 x 28,4 mm
              • Adapters M12/DIN
              • Adapters M12/DIN with electronic
              • Adapter DIN 43650 A
              • 180° Exit Cable
              • Circular connectors with moulded cable
              • Energy saving square connectors
            • B/ISO 6952 Industrial Form (10mm)
              • Field Attachable
              • Moulded Cable
            • B/ISO 6952 Industrial Form (11mm)
              • Field Attachable
              • Moulded Cable
              • Base type B
              • Adapter M12/DIN
              • Adapter M12/DIN with electronic
              • 180° Exit Cable
            • C-Micro(8mm)
              • Field Attachable
              • Moulded Cable
              • Base type C
              • Adapter M12/DIN
              • Adapter DIN 43650 C
            • C-Micro(9,4mm)
              • Field Attachable
              • Moulded Cable
              • Base type C
              • Adapter M12/DIN
              • 180° Exit Cable
            • UL Approved
              • UL Connectors
              • UL Connectors with electronic
              • UL Bases
            • ATEX 94/9/CE Approved
              • G2 Type ATEX
              • M1 Type ATEX
              • P1 Type ATEX
              • P2 Type ATEX
          • Fuse Holder
            • Fuse Holder
              • Fuse Holder
          • Automotive connectors
            • Automotive Connectors interchangeable with Deutsch Connectors
              • Moulded Cable
          • Distribution boxes M8/M12
            • M8 distribution Boxes
              • Terminal contacts
              • with PUR and PVC cable
              • with M12 Connection
            • M12 distribution Boxes
              • Terminal contacts
              • with terminal contacts with triple
              • With M23 exit cable
          • 7/8"
            • Field Attachable
              • Male Field Attachable
            • Moulded Cable
            • Panel Mounting
          • MIL-C5015 Style CONNECTORS
            • MIL-C5015 Style Connectors
              • Panel mounting
              • Field Attachable
          • Industrial connectors
            • Bases for industrial connectors
              • Cap for industrial connectors
          • En 175 000
            • EN 175 000 field attachable connectors
              • EN 175 000 female field attachable connectors
            • EN 175 000 panel mounting connectors
              • EN 175 000 male panel mounting connectors
          • Accessories
            • Timers
              • Digital Timer
            • Clip
              • Clip
              • Clip Adapter
            • M8/M12 Caps
              • M8/M12 caps for female connectors
              • M8/M12 caps female for male connectors
            • Plastic cable ties
            • Industrial lighting
          • Magnetic sensor
            • HSL
              • Sensor with cable
              • Sensor with M8 connector
            • HSC
              • Sensor with cable
            • HSA
              • Sensor with cable
            • HSS
              • Sensor with cable
            • HSN
              • Sensor with cable
            • HSM Connectors
              • Sensor with cable
              • Sensor with M12 connector
            • SM NC
              • Sensor with cable
            • HS R
              • Sensor with cable
            • HSM IP68
              • Sensor with cable
        • Cvilux
          • Application Tooling
            • Desk Top Machine
            • Hand Tool
          • Board to Board Connector
            • CB Series Header
            • CH Series Pin Header
          • FFC/FPC Connector
            • CF Series FFC/FPC Connector
          • I/O Connector
            • CD Series D-SUB Connector
            • CE Series Miniature Circular DIN
            • CJ Series Modular Plugs
            • CJ Series Telephome Phone Jacks
            • CR Series RF - Microwave - Coax Connectors
            • CU Series DVI Connector
            • CU Series IEEE 1394 Connector
            • CU Series USB Connector
            • Combo Series Combo D-SUB
            • RJ45 Series with Transformer Connector
            • CU Series Mini Display Port Connect
          • IC Socket
            • CS Series Multiple Shunts
            • CS Series Sockets
          • Power Connector
            • CP Series Board Mount Header
            • Cvilux Connector - CP Series Crimping Housing
            • CP Series Crimping Terminal
          • Wire To Board Connector
            • CA Series IDC Housing
            • CI Series Board Mount Header
            • CI Series Crimping Housing
            • CI Series Crimping Terminal
            • CI Series Wire Holder
            • CT Series Board in Terminal
            • CW Series Center Spacing Flat Cable
          • CCFL Connector
          • LVDS Connector
            • CVS Series LVDS Connector
        • Zoller & Fröhlich
          • Wire Ferrules
            • Single Bag
              • Loose ferrules
              • Twin ferrules
              • Special ferrules
            • Multiple bag
              • Loose ferrules
              • Twin ferrules
            • Wire ferrules on reel
            • Belt-strips
            • Uninsulated ferrules
      • Contacts
        • Deutsch
      • Accessories
        • Deutsch
      • Tools
        • Deutsch
    • Production Equipment
      • Cutting Machines
        • Ulmer
        • Tekuwa
        • Junquan
      • Stripping Machines
        • Zoller & Fröhlich
        • Feintechnik Rittmyer
      • Crimping equipment
        • Zoller & Fröhlich
        • Stocko
        • Mecal
      • Misc. Equipment
        • DSG Canusa
      • Ultrasonic Welding
        • Branson
  • Need to know
  • Linecard
  • About us
  • Home
  • Webshop
        • HongShang
          • Thin Wall Tubing
            • HB-1
            • H-2F(YG)(3X)
            • H-2R
            • H-2(CB)
          • Dual Wall Tubing
            • H-5(2000)
            • HBK
            • H-5(3X)-M
          • Special Products
            • HFSP
            • H-2(XT)/H-2(XT)HF
            • HTFE
            • H-200E/H-200E(TW)
            • HDR/HDR(TW)
            • H-175K
            • H-150K
        • DSG
          • Single Wall
            • Deray-H
          • Dual Wall
          • Medium Heavy Wall
          • Automotive
      • Connectors
          • Connectors
          • Accessories
          • Contacts
          • Tools
        • TE Connectivity
        • Stocko
            • PITCH 2.5 MM
            • PITCH 2.54 MM
            • PITCH 3.5 MM
            • PITCH 5 MM
            • PITCH 5.08 MM
            • PITCH 6.35 MM
            • PITCH 6.5 MM
            • PITCH 8 MM
            • PITCH 11.4 MM
            • PLUGS
            • PIN STRIPS
            • PCCR
          • Crimp Contacts
            • Receptacles
              • 2.8 MM
              • 4.8 MM
              • 6.3 MM
            • Tabs
              • 6.3 MM for fixing
              • 6.3 MM weld Tabs
              • Special types
              • C - Type
            • End splices
            • Sockets
            • Circular pins
          • Housing
            • Standard
            • 6.3 mm
            • Multi-way 6.3 mm
              • non insulated
              • pre insulated
            • Pin terminals
            • Parallel splices
            • Butt splices
            • Receptacles
            • Tabs
            • Sockets / Plugs
        • Vogt
              • Blind rivets
              • Blind rivet nuts
              • Hollow rivets
              • Tubular rivets
                • form C
                • form D
              • Rivets
            • Spacer
                • Internal thread
                • Internal thread
                • spacers UNC 4-40
                • snap-in
              • Cable clips
                • 1 mounting hole
                • 2 mounting hole
              • Clamping disks
                • Connecting disks
                • Clamping disks
                • Clamping straps
                • Clamping straps
                • Fastening angle
              • ornamental head
                • For hole < 1.3mm
                • For hole = 1.3mm
                • For hole > 1.3mm
                • In chain form
                • IDC contacts
              • Contact parts
              • Eyelet tags
              • Fuse holders
                • Diameter 5mm
                • Diameter 6.3mm
                • Diameter 8.5mm
                • Quartz holders
              • Contact caps
              • Wire-Wrap-Pins
                • From Wire
                • From Wire, bent
                • Stamped
              • Headers
                • Single Row
                • Single Row Angled
                • Double Row
                • Headers
                • Angle Pin Headers
              • In bulk
              • Soldering bridges
                • Jumpers for PCB
                • Insulated Jumpers
                • Bridge Connectors
                • Tag Blocks
            • SMD Stampings
                • Collar Sleeves
                • Rolled / Stamped
                • Seamless de tube
                • Special
              • Lamp holders
              • I.C. Sockets
              • Battery terminals
              • Battery contacts
            • Soldering tags
              • In bulk
                • 1 foot
                • 2 feet
                • bent
                • receptacles
                • flat
                • bent
                • receptacles
                • flat
                • bent
                • receptacles
                • grid 5 mm
                • grid 10 mm
                • angled, grid 5 mm
                • tab blocks ABB
                • rolled
                • bent
                • bent
                • tabs
                • Posilock
                • rolled
                • bent
                • screwable
              • housings for tabs
                • Dimension 2.8 mm
                • Dimension 2.8 mm
                • Dimension 6.3 mm
                • special
                • housings
                • plug pins form A
                • plug pins form B
                • plug pins
                • Chainform
            • end-sleeves
              • clips
                • chain
              • cable eyelets
                • F colors
                • D colors
                • F colors stripes
                • D colors stripes
                • F colors chain
                • D colors chain
                • F colors
                • D colors
            • Cable terminals
                • fork
                • ring, 3-way
                • ring 4-way
                • fork PVC
                • fork PA
                • ring form A
                • ring form B
                • fork form A
                • fork form B
                • hook
                • long hole
                • ring
                • fork
                • hook
              • crimp terminals
                • in bulk DIN 46225
              • Tubular terminals
                • flat
                • bent 90°
                • tight plate
              • flat with insul.
              • pin connectors
              • connector in PA
            • Boxes and sets
              • set with tool
              • set without tool
                • set without tool
              • box/set
            • chain
              • F colors chain
              • D colors chain
              • ring PVC
              • Ring PA
              • fork PVC
              • pin round
              • 1-pole 95°
              • 2-pole 95°
              • 4-pole 95°
            • Hand tools
              • Tools for wiring
                • wire stripper
                • tool
                • for blind rivets
                • for cable eyelets
                • for terminals
                • for end ferrules
                • for terminals
              • Manual air press
                • press head
              • Battery device
                • for stripes
              • Shrink apparatus
            • Presses
              • Inserting devices
                • applicator
                • spare parts
                • accessories
              • Riveting tools
                • Inserts
              • Manual presses
                • Manual presses
                • Lever presses
              • Pneumatic presses
                • press
                • tandem cylinder
                • Pneumatic gang
              • Machines
                • stripper-crimper
                • Manual air press
                • press body
                • scanning spot
        • HTP
            • Field Attachable
            • Moulded Cable
            • Panel mounting
            • T Connectors
              • T Connectors
            • Snap
              • Female Snap
              • Male Snap
            • Moulded Cable
            • A-Coded
              • Field Attachable
              • Moulded Cable
              • Panel mounting
            • B-Coded
              • Field Attachable
              • Moulded Cable
              • Panel mounting
            • C-Coded
              • Moulded Cable
              • Panel mounting
            • D-Coded
              • Field Attachable
              • Panel mounting
            • S-Coded
              • Moulded Cable
              • Panel mounting
            • T-Coded
              • Moulded Cable
              • Panel mounting
            • X-Coded
              • Panel mounting
              • Moulded Cable
            • Panel mounting
            • Moulded Cable
            • A/ISO 4400
              • Field Attachable
              • Moulded Cable
              • Adapters M12/DIN
              • 180° Exit Cable
              • Field Attachable
              • Moulded Cable
              • Field Attachable
              • Moulded Cable
              • Base type B
              • Adapter M12/DIN
              • 180° Exit Cable
            • C-Micro(8mm)
              • Field Attachable
              • Moulded Cable
              • Base type C
              • Adapter M12/DIN
            • C-Micro(9,4mm)
              • Field Attachable
              • Moulded Cable
              • Base type C
              • Adapter M12/DIN
              • 180° Exit Cable
            • UL Approved
              • UL Connectors
              • UL Bases
              • G2 Type ATEX
              • M1 Type ATEX
              • P1 Type ATEX
              • P2 Type ATEX
          • Fuse Holder
            • Fuse Holder
              • Fuse Holder
              • Moulded Cable
              • Terminal contacts
              • Terminal contacts
          • 7/8"
            • Field Attachable
            • Moulded Cable
            • Panel Mounting
              • Panel mounting
              • Field Attachable
          • En 175 000
          • Accessories
            • Timers
              • Digital Timer
            • Clip
              • Clip
              • Clip Adapter
            • M8/M12 Caps
          • Magnetic sensor
            • HSL
              • Sensor with cable
            • HSC
              • Sensor with cable
            • HSA
              • Sensor with cable
            • HSS
              • Sensor with cable
            • HSN
              • Sensor with cable
            • HSM Connectors
              • Sensor with cable
            • SM NC
              • Sensor with cable
            • HS R
              • Sensor with cable
            • HSM IP68
              • Sensor with cable
        • Cvilux
            • Desk Top Machine
            • Hand Tool
            • CB Series Header
          • FFC/FPC Connector
          • I/O Connector
          • IC Socket
            • CS Series Sockets
          • Power Connector
          • CCFL Connector
          • LVDS Connector
        • Zoller & Fröhlich
          • Wire Ferrules
            • Single Bag
              • Loose ferrules
              • Twin ferrules
              • Special ferrules
            • Multiple bag
              • Loose ferrules
              • Twin ferrules
            • Belt-strips
      • Contacts
        • Deutsch
      • Accessories
        • Deutsch
      • Tools
        • Deutsch
      • Cutting Machines
        • Ulmer
        • Tekuwa
        • Junquan
        • Zoller & Fröhlich
        • Zoller & Fröhlich
        • Stocko
        • Mecal
      • Misc. Equipment
        • DSG Canusa
        • Branson
  • Need to know
    Quality Management System
    • ISO 9001:2015
  • Linecard
  • About us
  • Home /
  • Webshop /
  • Industrial Components /
  • Accessories /
  • Deutsch
Deutsch
Items 226 to 250 of 438 total
Page:
  1. Previous
  2. 8
  3. 9
  4. 10
  5. 11
  6. 12
  7. Next
  • 2035366-2
    2035366-2
  • 2035366-3
    2035366-3
  • 2035366-4
    2035366-4
  • 2035366-7
    2035366-7
  • 2035366-8
    2035366-8
  • 2035366-9
    2035366-9
  • 2098436-1
    2098436-1
  • 2098436-2
    2098436-2
  • 2098436-3
    2098436-3
  • 2098436-4
    2098436-4
  • 2098436-7
    2098436-7
  • 2098436-8
    2098436-8
  • 2098436-9
    2098436-9
  • 2411-001-2405
    2411-001-2405
  • 2411-002-1805
    2411-002-1805
  • 2414-001-2486
    2414-001-2486
  • 2414-002-1886
    2414-002-1886
  • 2428-004-2405
    2428-004-2405
  • 2428-008-2405
    2428-008-2405
  • 2428-010-2405
    2428-010-2405
  • 2428-011-2405
    2428-011-2405
  • 2428-015-1805
    2428-015-1805
  • 2428-016-1805
    2428-016-1805
  • 2428-024-2405
    2428-024-2405
  • 2428-025-1805
    2428-025-1805
Page:
  1. Previous
  2. 8
  3. 9
  4. 10
  5. 11
  6. 12
  7. Next
Shop By Characteristics
Currently Shopping by:
  1. keyed: No Remove This Item
Clear All
Shopping Options
Series
  1. DT Series (151)
  2. DTM Series (66)
  3. DTP Series (26)
  4. AEC Series (10)
  5. AMPSEAL 16 Series (33)
  6. AMPSEAL Series (3)
  7. DRB Series (12)
  8. DRC Series (50)
  9. DTHD Series (12)
  10. DTV Series (5)
  11. HD10 Series (61)
  12. HD30 Series (44)
  13. HDP20 Series (38)
  14. STRIKE Series (11)
Brand
  1. Deutsch (438)
  2. TE Connectivity (36)
No. of cavities
  1. 2 (3)
  2. 3 (49)
  3. 4 (48)
  4. 5 (6)
  5. 6 (51)
  6. 8 (30)
  7. 9 (17)
  8. 12 (36)
  9. 13, 7.5 (3)
  10. 14 (1)
  11. 16, 20 (40)
  12. 18 (4)
  13. 24 (9)
  14. 40 (18)
  15. 50 (2)
  16. 60 (2)
  17. 64 (1)
  18. 70 (9)
  19. 102 (2)
Modification
  1. Chain with Eyelet, Chromated (2)
  2. Chain without Eyelet (3)
  3. Enhanced (8)
  4. Nitrile Lanyard (7)
  5. No Chain (3)
  6. Steel Lanyard (6)
Shape
  1. Circular (38)
  2. Rectangular (13)
  3. Triangular (1)
Material
  1. Aluminum (13)
  2. Fluorosilicone (1)
  3. Metal (11)
  4. Neoprene (15)
  5. Plastic (242)
  6. Plastisol (97)
  7. Rubber (2)
  8. Silicone Rubber (37)
  9. Stainless steel (6)
  10. Stainless Steel (1)
  11. Steel (12)
Connector Style
  1. Plug (123)
  2. Plug, Receptacle (65)
  3. Receptacle (158)
Color
  1. Black (204)
  2. Blue (1)
  3. Gray (78)
  4. Green (14)
  5. Natural (1)
  6. Orange (60)
  7. Red (4)
  8. Silver (30)
  9. White (6)
  10. Yellow (25)
  11. Zinc (5)
Estonia
Phone: + 372 671 22 51
Fax: + 372 671 22 53
E-mail
info@gammeter.ee
Parent Company
Gammeter OÜ
Paldiski mnt 31/1
76606 Keila
Estonia
Sweden
Phone: +46 (0)8-445 36 00
Fax: +46 (0)8-445 36 10
E-mail
info@adcontact.se
Sales office
Adcontact AB
Ursviksvägen 127A
SE-174 46 Sundbyberg
Sweden
Finland
Phone: +358 3 380 22 11
Fax: +358 3 380 22 44
E-mail
info@gammeter.fi
Sales office
Gammeter OÜ
Vehnämyllynkatu 6
FIN-33560 Tammerfors
Finland
Norway
Phone: +47 224 177 00
Fax: +47 224 177 01
E-mail
info@adcontact.se
Sales office
Adcontact AB
Postboks 246 Skøyen
NO-0213 Oslo
Norway
Terms of delivery Shipping information Payment information
© 2019 Adcontact – Webbshop av Lybe
To top
