CI Series Crimping Housing
CI94 Series 1.27mm(.050) Serial ATA Power Female Connectors With Latch Type Housing
CI94 Series 1.27mm(.050) Serial ATA Power Female Connectors IDC With Latch Type
CI94 Series 1.27mm(.050) Serial ATA Power Female Connectors IDC Type
CI94 Series 1.27mm(.050) Serial ATA Power Receptacle Connector Solder Type
CI94 Series Serial ATA Power Receptacle Connector Crimp Type
CI94 Plastic Latch Series 1.27mm(.050) Serial ATA Power Receptacle Connector Molding Type
CI94 Plastic Latch Series 1.27mm(.050) Serial ATA Power Receptacle Connector IDC With Latch Type
CI94 Plastic Latch Series1.27mm(.050) Serial ATA Power Receptacle Connector
CI94 Series Serial ATA Power Receptacle Connector Molding Type
CI44 Series 1.25mm(.049) Wire to Board Crimp Housing
CI42 Series 1.25mm (.049) Single Row Wire to Board Crimp Housing
CI14 Series 1.00mm(.039) Wire to Board Crimp Housing
CI11 Series 1.00mm(.039) Dual Row Wire to Board Crimp Housing
CI11 Series 1.00mm(.039) Wire to Board Crimp Housing
CI09 Series 2.0mm(.079")Wire to Board Connectors Housing
CI07 Serise 1.80mm Pitch Housing
CI06 Series 2.00mm(.079) Wire to Board Crimp Housing
CI04 Series 2.00mm(.079) Dual Row Wire to Board Crimp Housing
CI03 Series 2.00mm(.079) Wire to Board Crimp Housing
CI02 Series 2.00mm(.079) Board In Connector
CI01 Series 2.00mm(.079)Dual Row wire to Board crimp Housing
CI01 Series 2.00mm(.079) Dual Row wire to Board Crimp Housing(With Latch)
CI01 Series 2.00mm (.079) Single Row Wire to Board Crimp Housing
CI01 Series 2.00mm(.079)Dual Row wire to wire Connectors
