AdcontactAdcontact
Cart
0
You have no items in your shopping cart.
Compare
(0)
You have no items to compare.
  • Account
  • Wishlist
  • Log In
  • Sign Up
Menu
  • Webshop
    • Industrial Components
      • Heat Shrink Tubing
        • HongShang
          • Thin Wall Tubing
            • HB-1
            • H-2F(YG)(3X)
            • Flexible / 2:1 / for flexible gas pipes / HBG
            • Flexible / flame retardant / 2:1 / low shrink temperature / H-2(LS)
            • Yellow/green striped / flexible / flame retardant / 2:1/3:1 / mil spec 135 degrees / H-2F(Y/G)
            • Flexible / flame retardant / 4:1 / mil spec 135 degrees / H-2F(4X)
            • Flexible / flame retardant / 3:1 / mil spec 135 degrees / H-2F(3X)
            • Flexible / flame retardant / 2:1 / mil spec 135 degrees / H-2F
            • H-2R
            • Flexible / flame retardant / 2:1 / halogen free / H-2(HF)
            • H-2(CB)
            • Flexible / flame retardant / 3:1 / H-2(3X)
            • Flexible / flame retardant / 2:1 / H-2(Z)
            • Non flame retardant / 2:1 / H-1
          • Dual Wall Tubing
            • H-5(2000)
            • HBK
            • H-5(3X)-M
            • H-5(3X)-F / H-5(4X)-F
            • H-5(3X) / H-5(4X)/H-5(2X)
          • Special Products
            • HFSP
            • H-2(XT)/H-2(XT)HF
            • HTFE
            • H-200E/H-200E(TW)
            • HDR/HDR(TW)
            • H-175K
            • H-150K
          • Selection Table Heat Shrink Tubing
        • DSG
          • Single Wall
            • Deray-H
          • Dual Wall
          • Medium Heavy Wall
          • Specialty Non-Polyolefin
          • Automotive
          • Canuflex - Braided Sleeves
          • Electrical & Utilities Products
      • Connectors
        • Deutsch Connectors
          • Connectors
          • Accessories
          • Contacts
          • Tools
        • TE Connectivity
        • Stocko
          • Stocko Connectors, Connector Systems
            • PITCH 2.5 MM
            • PITCH 2.54 MM
            • PITCH 3.5 MM
            • PITCH 4.2 MM Connector
            • PITCH 5 MM
            • PITCH 5.08 MM
            • PITCH 5.08/7.62 MM
            • PITCH 6.35 MM
            • PITCH 6.5 MM
            • PITCH 8 MM
            • PITCH 11.4 MM
            • PLUGS
            • PIN STRIPS
            • PCCR
          • Crimp Contacts
            • Receptacles
              • 2.8 MM
              • 4.8 MM
              • 6.3 MM
            • Tabs
              • 2.8 MM/ 4.8 MM/ 6.3 MM
              • 6.3 MM for fixing
              • 6.3 MM weld Tabs
              • 4.8 MM for fixing and welding
            • Printed boards contacts
            • Open barrel terminals
              • Without insulation chrimp
              • With insulation crimp
              • Special types
              • C - Type
            • Special connectors
            • End splices
            • Sockets
            • Circular pins
          • Housing
            • Standard
            • Self-locking 4.8 mm
            • 6.3 mm
            • Multi-way 6.3 mm
            • Multi-way self-locking 2.8 - 6.3 mm
            • Multi-way self-locking 6.3 mm
          • Solderless Terminals
            • Solderless terminals
              • non insulated
              • pre insulated
            • Pin terminals
            • Parallel splices
            • Butt splices
            • Receptacles
            • Tabs
            • Sockets / Plugs
        • Vogt
          • Riveting technique / Mechanical elements
              • Blind rivets
                • flat head DIN 7337 A, *excepted
                • flat head DIN 7337 A bargin sales
                • countersunk head DIN 7337 B, *excepted
              • Blind rivet nuts
              • Flaning full rivets
                • mushroom head DIN 6791,, *excepted
                • flat head DIN 7338 *excepted
              • Hollow rivets
              • Tubular rivets
                • DIN 7340 A, * excepted Ø 0,8 - 1,9
                • DIN 7340 A, * excepted Ø 2,0 - 2,4
                • DIN 7340 A, * excepted Ø 2,5 - 3,0
                • DIN 7340 A, * excepted Ø 3,1 - 16
                • DIN 7340 B, * excepted Ø 0,8 - 1,9
                • DIN 7340 B, * excepted Ø 2,0 - 2,4
                • DIN 7340 B, * excepted Ø 2,5 - 3,0
                • DIN 7340 B, * excepted Ø 3,1 - 16
                • form C
                • form D
              • Rivets
                • rivets with snap head DIN660, *excepted
                • riv.w.countersunk head DIN 661, *excepted
                • rivets w.flat round head DIN674, *excepted
            • Spacer
              • Spacers brass nickelplated
                • Internal thread
                • with internal thread on both sides
                • with internal and external thread
              • Spacer steel zinc-plated
                • Internal thread
                • spacers UNC 4-40
              • Insulating spacers
                • with external thread on both sides
                • snap in form with external thread
                • snap in form with internal thread
                • snap in form with head
                • snap-in
                • with internal and external metal thread
                • with threaded-end rod of metal
                • cap nut with internal metal thread
                • cap bolt with external metal thread
              • crimping sleeves Ø 0,1 - 4,9 mm
              • crimping sleeves Ø 5 - 10 mm
              • crimping sleeves Ø 10 - 20 mm
              • cylindrical tubular pces
              • cylindrical tubular pces Ø 2,5 - 21
              • spacer sleeves metal Ø 1,0 - 5,9
              • spacer sleeves metal Ø 6,0 - 18
              • Cable clips
                • 1 mounting hole
                • 2 mounting hole
                • Special cable clips
              • Clamping disks
                • Connecting disks
                • Clamping disks
                • Clamping straps
                • Clamping straps
                • Fastening angle
              • Washers Ø 0,4 - 3,2
              • Washers Ø 3,3 - 5,9
              • Washers Ø 6,0 - 50,0
              • ornamental head
          • Contact pieces for PCB / Soldering tags
            • Soldering parts for PCB
              • Soldering lugs for PCB
                • For hole < 1.3mm
                • For hole = 1.3mm
                • For hole > 1.3mm
                • Special soldering lugs
                • In chain form
                • Soldering lug bars
                • IDC contacts
              • Contact parts
              • Eyelet tags
              • Small stamping parts
              • Fuse holders
                • Diameter 5mm
                • Diameter 6.3mm
                • Diameter 8.5mm
                • Quartz holders
              • Contact caps
              • Wire-Wrap-Pins
                • From Wire
                • From Wire, bent
                • Stamped
                • Receptacles for Wrap-Pins
              • Headers
                • Single Row
                • Single Row Angled
                • Double Row
                • Headers
                • Angle Pin Headers
                • Angle Pin Headers Tapeform
              • In bulk
              • PCB Spring contacts
              • Contacts to push-on
              • Soldering bridges
                • Jumpers for PCB
                • Insulated Jumpers
                • Bridge Connectors
                • Tag Blocks
              • R.C.B terminal blocks
            • SMD Stampings
            • Tubular - and turned parts for PCB
              • Seamless plugs soldering tags Collar sleeves
                • Collar Sleeves
                • Double Collar Sleeve
                • Seamless plug pins
                • Rolled / Stamped
                • Seamless de tube
                • Special
              • Connecting eyelets f. PCB
              • Plug pins from wire Contact parts
              • Electro-stamping parts
              • Lamp holders
              • I.C. Sockets
              • Battery terminals
              • Battery contacts
            • Soldering tags
              • Soldering tags, 1 tag
              • Soldering tags, 2 tags
              • Soldering tags, multi tags
              • Soldering tags special
              • Eyelet tags, 1 tag
              • Eyelet tags, multi tags
              • In bulk
            • Mounting tabs and for PCB
              • Dimension nominally 2.8 mm
                • 1 foot
                • 2 feet
                • bent
                • receptacles
                • Press-in technology
              • Dimension nominally 4.8 mm
                • flat
                • bent
                • receptacles
              • Dimension nominally 6.3 mm
                • flat
                • bent
                • receptacles
                • Press-fit technology
              • Dimension nominally 9.5 mm
              • Tab blocks for PCB
                • grid 5 mm
                • grid 10 mm
                • angled, grid 5 mm
                • tab blocks ABB
                • insulated cup washers
            • Soldering parts for PCB reflow
          • Cable terminals / Solderless splices
            • Tabs screwable and weldable
            • Flat- and round connectors
              • Receptacles and tabs 2.8 mm
                • DIN 46247 / part 1
                • DIN 46340 / part 1
                • rolled
                • bent
              • multi connectors 2.8 mm
              • Receptacles and tabs insulated 2.8 mm
                • part. insul. PVC DIN 46245 part 1 with extra support-sleeve
                • part. insul. without extra support-sleeve
                • insul. PA with extra support-sleeve
                • insul. PA without extra support-sleeve
              • Receptacles and tabs 4.8 mm
                • DIN 46247 / part 2
                • bent
                • tabs
                • Posilock
                • with snap-in tongue
              • multi connectors 4.8 mm
              • Receptacles and tabs insulated 4.8 mm
                • part. insul. PVC DIN 46245 part 2 with extra support-sleeve
                • insul. PVC with extra support-sleeve
                • insul. PVC without extra support-sleeve
                • part. insul. with extra support-sleeve
                • insul. PA bent sithout extra support-sleeve
              • Receptacles for pins in chain form 4.8 mm
                • receptacles for pins in chain form un-insulated DIN 46247 part 2
                • multi-connector in chain form un-insulated
                • receptacles for pin in chain form part. insulated PVC
                • receptacles for pins in chain form insulated PA
                • tabs in chain form un-insulated
              • Receptaclesa dn tabs 6.3 mm
                • DIN 46347 / part 3
                • DIN 46340 / part 3
                • rolled
                • tabs DIN 46248 part 3
                • bent
                • screwable
              • multi connectors 6.3 mm
              • Receptacles insulated 6.3 mm
                • part. insul. PVC DIN 46245 part 3 with extra support-sleeve
                • part. insul. heat shrinkable with extra support-sleeve
                • insul. heat shrinkable with extra support-sleeve
                • insul. PA heat shrinkable without extra support-sleeve
                • multi-connector part insul. PVC with extra support-sleeve
                • multi-connector part insul. PVC without extra support-sleeve
              • Receptacles for pins in chain form 6.3 mm
                • receptacles for pins in chain form un-insulated DIN 46247 part 3
                • receptacles for pins in chain form bent un-insulated
                • tabs in chain form part. insulated PVC
                • receptacles for pins in chain form part. insulated PVC.
              • housings for tabs
                • Dimension 2.8 mm
                • Dimension 2.8 mm
                • Dimension 6.3 mm
                • special
                • housings
              • receptacles 7.7 mm
              • receptacles 9.5 mm
              • Receptacles insulated 9,5 mm
              • branch terminals IDC
              • pin connectors insulated
                • receptacles for pins insul. PVC with extra support-sleeve
                • receptcles for pin insul. PVC without extra support-sleeve
                • plug part. insul. PVC with extra support-sleeve
                • plug part. insul. PVC without extra support-sleeve
              • Pin connectors and round receptacles un-insulated
                • plug pins form A
                • plug pins form B
                • plug pins
                • Chainform
              • heat-shrinkable sleeves
            • end-sleeves
              • copper DIN 46228/1 0,1 - 2,5 mm² *excepted
              • copper DIN 46228/1 4,0 - 95 mm² *excepted
              • copper DIN 46228/1 120 - 150 mm² *excepted
              • from brass 0,1 - 4,0 mm²
              • from brass 6,0 - 150 mm²
              • clips
                • in bulk DIN 46225 part 2
                • chain
              • boxes end splices un-insulated
              • cable eyelets
            • end-sleeves insulated
              • end-sleeves insulated with PP
                • DIN 46228/4 colors, *excepted
                • F colors
                • D colors
                • boxes end splices insulated
              • end-sleeves chainform with PP
                • DIN 46228/4 colors stripes
                • F colors stripes
                • D colors stripes
                • F colors chain
                • D colors chain
              • twincable sleeves with PP
                • F colors
                • D colors
              • end-sleeves for short circuit proof and earth fault current with PA
            • Cable terminals
              • solderless terminals
                • ring DIN 46234, *excepted
                • fork
                • ring, 3-way
                • ring 4-way
                • set terminals uninsulated
              • solderless terminals insulated
                • ring PVC DIN 46237, *excepted
                • ring PA DIN 46237, * excepted
                • ring heatshrinkable
                • fork PVC
                • fork PA
                • fork heatshrinkable
                • ring, insulated PVC 4-way
                • ring, insulated PVC 3-way
                • set terminals with insulation
              • soldering terminals, open
                • ring form A
                • ring form B
                • fork form A
                • fork form B
                • hook
                • telephone DIN 46257
                • long hole
              • Soldering terminals, rolled
                • ring DIN 46211, *excepted
                • ring
                • fork DIN 46211, * excepted
                • fork
                • hook
              • crimp terminals
                • in bulk DIN 46225
                • in chain form DIN 46225
              • Tubular terminals
                • flat
                • bent 90°
                • tight plate
              • flat with insul.
              • parallel connectors
              • Butt-splices insulated
              • butt-splices, un-insulated
              • reducing butt-splices un-insulated
              • pin connectors
                • pin round DIN 46230, *excepted
                • pin flat DIN 46230, * excepted
                • pin round PVC DIN 46231, *excepted
                • pin round PA DIN 46231, *excepted
              • connector in PA
            • Boxes and sets
              • set with tool
              • set without tool
                • set without tool
              • bag for replenishment
              • box/set
            • chain
              • F colors chain
              • D colors chain
              • ring PVC
              • Ring PA
              • fork PVC
              • pin round
              • Receptacles for pins in chain form 2.8 mm
                • receptacles for pins in chain form un-insulated DIN 46247 part 1
            • tab bloc with blind rivet
              • 1-pole 95°
              • 2-pole 95°
              • 4-pole 95°
          • Hand tools / Presses and accessories
            • Hand tools
              • Striker spring press
                • ransition piece for tips from presses
              • Tools for wiring
                • wire stripper
                • tool
              • Hand riveting tools
                • for blind rivets
                • for blind rivets nuts
                • for tubular rivets
                • for cable eyelets
              • push on tool f.recept.
              • Crimping tools eco-line
                • for un-insulated terminals
                • for insulated terminals
                • for receptacles for pins bent
                • for terminals
                • for terminals bent
                • for end ferrules
                • Interchangeable dies
              • Crimping tolls professional-line
                • for terminals
                • MCT Mobile Crimping Tool
              • Manual air press
                • press head
                • press head with exchangeable dies
                • spare parts for air press
                • accessories for manual air press
              • Battery device
              • Hand-tools for ferrules
                • for parts in bulk, Eco-Line
                • for parts in bulk, Profi-Line
                • for stripes
              • Shrink apparatus
              • Bargain sales hand tools
            • Presses
              • Inserting devices
                • applicator
                • spare parts
                • accessories
              • Riveting tools
                • Inserts
                • pick-up attachment
              • Manual presses
                • Connecting eyelets f. PCB presses
                • manual riveting press
                • Manual presses
                • Lever presses
              • Pneumatic presses
                • press
                • tandem cylinder
                • Pneumatic gang
                • Bargain sales pneumatic presses
              • Machines
                • strip and twist machine
                • stripper-crimper
                • electr.auto crimp.machine
                • Manual air press
                • Bargain sales machines
              • accessories for presses
                • press body
                • lengthening for throat
                • scanning spot
                • Bargain sales accessories for presses
                • Spare parts for press
        • HTP
          • M8 Circular Connectors
            • Field Attachable
              • Female field attachable with screw contacts
              • Field Attachable with soldered contacts
              • Male field attachable with screw contacts
              • Male field attachable with soldered contacts
            • Moulded Cable
              • PVC o PUR moulded cable
              • Totally shielded with PVC or PUR shielded cable
              • With PNP or NPN Led and PVC o PUR moulded cable
            • Panel mounting
              • Female panel mounting with wires
              • Male panel mounting with wires
              • Female panel mounting with soldered contacts
              • Male panel mounting with soldered contacts
              • Female panel mounting for PCB
              • Male panel mounting for PCB
              • Panel mounting adapter
            • T Connectors
              • T Connectors
            • Snap
              • Female Snap
              • Male Snap
            • Field attachable ATEX
              • Field attachable with screw contacts
              • Field attachable with soldered contacts
          • M9 Circular Connectors
            • Moulded Cable
              • Female Moulded Cable
              • Male Moulded Cable
          • M12 Circular Connectors
            • A-Coded
              • Field Attachable
              • Moulded Cable
              • Panel mounting
              • T-Splitter Connectors
            • B-Coded
              • Field Attachable
              • Moulded Cable
              • Panel mounting
            • C-Coded
              • Moulded Cable
              • Panel mounting
            • D-Coded
              • Field Attachable
              • Panel mounting
            • S-Coded
              • Moulded Cable
              • Panel mounting
            • T-Coded
              • Moulded Cable
              • Panel mounting
            • X-Coded
              • Panel mounting
              • Moulded Cable
          • M23 Circular Connectors
            • Panel mounting
              • With contacts for PCB
            • Moulded Cable
          • EN 175301-803 (ex DIN 43650)
            • A/ISO 4400
              • Field Attachable
              • Field attachable with electronic components
              • Moulded Cable
              • Moulded Cable with electronic components
              • Base type A 28,4 x 28,4 mm
              • Adapters M12/DIN
              • Adapters M12/DIN with electronic
              • Adapter DIN 43650 A
              • 180° Exit Cable
              • Circular connectors with moulded cable
              • Energy saving square connectors
            • B/ISO 6952 Industrial Form (10mm)
              • Field Attachable
              • Moulded Cable
            • B/ISO 6952 Industrial Form (11mm)
              • Field Attachable
              • Moulded Cable
              • Base type B
              • Adapter M12/DIN
              • Adapter M12/DIN with electronic
              • 180° Exit Cable
            • C-Micro(8mm)
              • Field Attachable
              • Moulded Cable
              • Base type C
              • Adapter M12/DIN
              • Adapter DIN 43650 C
            • C-Micro(9,4mm)
              • Field Attachable
              • Moulded Cable
              • Base type C
              • Adapter M12/DIN
              • 180° Exit Cable
            • UL Approved
              • UL Connectors
              • UL Connectors with electronic
              • UL Bases
            • ATEX 94/9/CE Approved
              • G2 Type ATEX
              • M1 Type ATEX
              • P1 Type ATEX
              • P2 Type ATEX
          • Fuse Holder
            • Fuse Holder
              • Fuse Holder
          • Automotive connectors
            • Automotive Connectors interchangeable with Deutsch Connectors
              • Moulded Cable
          • Distribution boxes M8/M12
            • M8 distribution Boxes
              • Terminal contacts
              • with PUR and PVC cable
              • with M12 Connection
            • M12 distribution Boxes
              • Terminal contacts
              • with terminal contacts with triple
              • With M23 exit cable
          • 7/8"
            • Field Attachable
              • Male Field Attachable
            • Moulded Cable
            • Panel Mounting
          • MIL-C5015 Style CONNECTORS
            • MIL-C5015 Style Connectors
              • Panel mounting
              • Field Attachable
          • Industrial connectors
            • Bases for industrial connectors
              • Cap for industrial connectors
          • En 175 000
            • EN 175 000 field attachable connectors
              • EN 175 000 female field attachable connectors
            • EN 175 000 panel mounting connectors
              • EN 175 000 male panel mounting connectors
          • Accessories
            • Timers
              • Digital Timer
            • Clip
              • Clip
              • Clip Adapter
            • M8/M12 Caps
              • M8/M12 caps for female connectors
              • M8/M12 caps female for male connectors
            • Plastic cable ties
            • Industrial lighting
          • Magnetic sensor
            • HSL
              • Sensor with cable
              • Sensor with M8 connector
            • HSC
              • Sensor with cable
            • HSA
              • Sensor with cable
            • HSS
              • Sensor with cable
            • HSN
              • Sensor with cable
            • HSM Connectors
              • Sensor with cable
              • Sensor with M12 connector
            • SM NC
              • Sensor with cable
            • HS R
              • Sensor with cable
            • HSM IP68
              • Sensor with cable
        • Cvilux
          • Application Tooling
            • Desk Top Machine
            • Hand Tool
          • Board to Board Connector
            • CB Series Header
            • CH Series Pin Header
          • FFC/FPC Connector
            • CF Series FFC/FPC Connector
          • I/O Connector
            • CD Series D-SUB Connector
            • CE Series Miniature Circular DIN
            • CJ Series Modular Plugs
            • CJ Series Telephome Phone Jacks
            • CR Series RF - Microwave - Coax Connectors
            • CU Series DVI Connector
            • CU Series IEEE 1394 Connector
            • CU Series USB Connector
            • Combo Series Combo D-SUB
            • RJ45 Series with Transformer Connector
            • CU Series Mini Display Port Connect
          • IC Socket
            • CS Series Multiple Shunts
            • CS Series Sockets
          • Power Connector
            • CP Series Board Mount Header
            • Cvilux Connector - CP Series Crimping Housing
            • CP Series Crimping Terminal
          • Wire To Board Connector
            • CA Series IDC Housing
            • CI Series Board Mount Header
            • CI Series Crimping Housing
            • CI Series Crimping Terminal
            • CI Series Wire Holder
            • CT Series Board in Terminal
            • CW Series Center Spacing Flat Cable
          • CCFL Connector
          • LVDS Connector
            • CVS Series LVDS Connector
        • Zoller & Fröhlich
          • Wire Ferrules
            • Single Bag
              • Loose ferrules
              • Twin ferrules
              • Special ferrules
            • Multiple bag
              • Loose ferrules
              • Twin ferrules
            • Wire ferrules on reel
            • Belt-strips
            • Uninsulated ferrules
      • Contacts
        • Deutsch
      • Accessories
        • Deutsch
      • Tools
        • Deutsch
    • Production Equipment
      • Cutting Machines
        • Ulmer
        • Tekuwa
        • Junquan
      • Stripping Machines
        • Zoller & Fröhlich
        • Feintechnik Rittmyer
      • Crimping equipment
        • Zoller & Fröhlich
        • Stocko
        • Mecal
      • Misc. Equipment
        • DSG Canusa
      • Ultrasonic Welding
        • Branson
  • Need to know
  • Linecard
  • About us
  • Home
  • Webshop
        • HongShang
          • Thin Wall Tubing
            • HB-1
            • H-2F(YG)(3X)
            • H-2R
            • H-2(CB)
          • Dual Wall Tubing
            • H-5(2000)
            • HBK
            • H-5(3X)-M
          • Special Products
            • HFSP
            • H-2(XT)/H-2(XT)HF
            • HTFE
            • H-200E/H-200E(TW)
            • HDR/HDR(TW)
            • H-175K
            • H-150K
        • DSG
          • Single Wall
            • Deray-H
          • Dual Wall
          • Medium Heavy Wall
          • Automotive
      • Connectors
          • Connectors
          • Accessories
          • Contacts
          • Tools
        • TE Connectivity
        • Stocko
            • PITCH 2.5 MM
            • PITCH 2.54 MM
            • PITCH 3.5 MM
            • PITCH 5 MM
            • PITCH 5.08 MM
            • PITCH 6.35 MM
            • PITCH 6.5 MM
            • PITCH 8 MM
            • PITCH 11.4 MM
            • PLUGS
            • PIN STRIPS
            • PCCR
          • Crimp Contacts
            • Receptacles
              • 2.8 MM
              • 4.8 MM
              • 6.3 MM
            • Tabs
              • 6.3 MM for fixing
              • 6.3 MM weld Tabs
              • Special types
              • C - Type
            • End splices
            • Sockets
            • Circular pins
          • Housing
            • Standard
            • 6.3 mm
            • Multi-way 6.3 mm
              • non insulated
              • pre insulated
            • Pin terminals
            • Parallel splices
            • Butt splices
            • Receptacles
            • Tabs
            • Sockets / Plugs
        • Vogt
              • Blind rivets
              • Blind rivet nuts
              • Hollow rivets
              • Tubular rivets
                • form C
                • form D
              • Rivets
            • Spacer
                • Internal thread
                • Internal thread
                • spacers UNC 4-40
                • snap-in
              • Cable clips
                • 1 mounting hole
                • 2 mounting hole
              • Clamping disks
                • Connecting disks
                • Clamping disks
                • Clamping straps
                • Clamping straps
                • Fastening angle
              • ornamental head
                • For hole < 1.3mm
                • For hole = 1.3mm
                • For hole > 1.3mm
                • In chain form
                • IDC contacts
              • Contact parts
              • Eyelet tags
              • Fuse holders
                • Diameter 5mm
                • Diameter 6.3mm
                • Diameter 8.5mm
                • Quartz holders
              • Contact caps
              • Wire-Wrap-Pins
                • From Wire
                • From Wire, bent
                • Stamped
              • Headers
                • Single Row
                • Single Row Angled
                • Double Row
                • Headers
                • Angle Pin Headers
              • In bulk
              • Soldering bridges
                • Jumpers for PCB
                • Insulated Jumpers
                • Bridge Connectors
                • Tag Blocks
            • SMD Stampings
                • Collar Sleeves
                • Rolled / Stamped
                • Seamless de tube
                • Special
              • Lamp holders
              • I.C. Sockets
              • Battery terminals
              • Battery contacts
            • Soldering tags
              • In bulk
                • 1 foot
                • 2 feet
                • bent
                • receptacles
                • flat
                • bent
                • receptacles
                • flat
                • bent
                • receptacles
                • grid 5 mm
                • grid 10 mm
                • angled, grid 5 mm
                • tab blocks ABB
                • rolled
                • bent
                • bent
                • tabs
                • Posilock
                • rolled
                • bent
                • screwable
              • housings for tabs
                • Dimension 2.8 mm
                • Dimension 2.8 mm
                • Dimension 6.3 mm
                • special
                • housings
                • plug pins form A
                • plug pins form B
                • plug pins
                • Chainform
            • end-sleeves
              • clips
                • chain
              • cable eyelets
                • F colors
                • D colors
                • F colors stripes
                • D colors stripes
                • F colors chain
                • D colors chain
                • F colors
                • D colors
            • Cable terminals
                • fork
                • ring, 3-way
                • ring 4-way
                • fork PVC
                • fork PA
                • ring form A
                • ring form B
                • fork form A
                • fork form B
                • hook
                • long hole
                • ring
                • fork
                • hook
              • crimp terminals
                • in bulk DIN 46225
              • Tubular terminals
                • flat
                • bent 90°
                • tight plate
              • flat with insul.
              • pin connectors
              • connector in PA
            • Boxes and sets
              • set with tool
              • set without tool
                • set without tool
              • box/set
            • chain
              • F colors chain
              • D colors chain
              • ring PVC
              • Ring PA
              • fork PVC
              • pin round
              • 1-pole 95°
              • 2-pole 95°
              • 4-pole 95°
            • Hand tools
              • Tools for wiring
                • wire stripper
                • tool
                • for blind rivets
                • for cable eyelets
                • for terminals
                • for end ferrules
                • for terminals
              • Manual air press
                • press head
              • Battery device
                • for stripes
              • Shrink apparatus
            • Presses
              • Inserting devices
                • applicator
                • spare parts
                • accessories
              • Riveting tools
                • Inserts
              • Manual presses
                • Manual presses
                • Lever presses
              • Pneumatic presses
                • press
                • tandem cylinder
                • Pneumatic gang
              • Machines
                • stripper-crimper
                • Manual air press
                • press body
                • scanning spot
        • HTP
            • Field Attachable
            • Moulded Cable
            • Panel mounting
            • T Connectors
              • T Connectors
            • Snap
              • Female Snap
              • Male Snap
            • Moulded Cable
            • A-Coded
              • Field Attachable
              • Moulded Cable
              • Panel mounting
            • B-Coded
              • Field Attachable
              • Moulded Cable
              • Panel mounting
            • C-Coded
              • Moulded Cable
              • Panel mounting
            • D-Coded
              • Field Attachable
              • Panel mounting
            • S-Coded
              • Moulded Cable
              • Panel mounting
            • T-Coded
              • Moulded Cable
              • Panel mounting
            • X-Coded
              • Panel mounting
              • Moulded Cable
            • Panel mounting
            • Moulded Cable
            • A/ISO 4400
              • Field Attachable
              • Moulded Cable
              • Adapters M12/DIN
              • 180° Exit Cable
              • Field Attachable
              • Moulded Cable
              • Field Attachable
              • Moulded Cable
              • Base type B
              • Adapter M12/DIN
              • 180° Exit Cable
            • C-Micro(8mm)
              • Field Attachable
              • Moulded Cable
              • Base type C
              • Adapter M12/DIN
            • C-Micro(9,4mm)
              • Field Attachable
              • Moulded Cable
              • Base type C
              • Adapter M12/DIN
              • 180° Exit Cable
            • UL Approved
              • UL Connectors
              • UL Bases
              • G2 Type ATEX
              • M1 Type ATEX
              • P1 Type ATEX
              • P2 Type ATEX
          • Fuse Holder
            • Fuse Holder
              • Fuse Holder
              • Moulded Cable
              • Terminal contacts
              • Terminal contacts
          • 7/8"
            • Field Attachable
            • Moulded Cable
            • Panel Mounting
              • Panel mounting
              • Field Attachable
          • En 175 000
          • Accessories
            • Timers
              • Digital Timer
            • Clip
              • Clip
              • Clip Adapter
            • M8/M12 Caps
          • Magnetic sensor
            • HSL
              • Sensor with cable
            • HSC
              • Sensor with cable
            • HSA
              • Sensor with cable
            • HSS
              • Sensor with cable
            • HSN
              • Sensor with cable
            • HSM Connectors
              • Sensor with cable
            • SM NC
              • Sensor with cable
            • HS R
              • Sensor with cable
            • HSM IP68
              • Sensor with cable
        • Cvilux
            • Desk Top Machine
            • Hand Tool
            • CB Series Header
          • FFC/FPC Connector
          • I/O Connector
          • IC Socket
            • CS Series Sockets
          • Power Connector
          • CCFL Connector
          • LVDS Connector
        • Zoller & Fröhlich
          • Wire Ferrules
            • Single Bag
              • Loose ferrules
              • Twin ferrules
              • Special ferrules
            • Multiple bag
              • Loose ferrules
              • Twin ferrules
            • Belt-strips
      • Contacts
        • Deutsch
      • Accessories
        • Deutsch
      • Tools
        • Deutsch
      • Cutting Machines
        • Ulmer
        • Tekuwa
        • Junquan
        • Zoller & Fröhlich
        • Zoller & Fröhlich
        • Stocko
        • Mecal
      • Misc. Equipment
        • DSG Canusa
        • Branson
  • Need to know
    Quality Management System
    • ISO 9001:2015
  • Linecard
  • About us
  • Home /
  • Webshop /
  • Industrial Components /
  • Connectors /
  • Vogt
Vogt
Vogt
Contact pieces for PCB Soldering tags
Items 76 to 100 of 175 total
Page:
  1. Previous
  2. 2
  3. 3
  4. 4
  5. 5
  6. 6
  7. Next
  • cable sleeves 4508b30.67
  • twincable sleeves 470312d
  • cable sleeves 440710.47
  • cable sleeves 451130.67
  • twincable sleeves 490206d
  • cable sleeves 440818.47
  • cable sleeves 451430.67
  • cable sleeves 440106.47
  • cable sleeves 441112.47
  • cable sleeves 440212.47
  • cable sleeves 450006.67
  • twincable sleeves 460206d
  • cable sleeves 440408.47
  • cable sleeves 450407.67
  • twincable sleeves 460512d
  • cable sleeves 440510.47
  • cable sleeves 4508b12.67
  • twincable sleeves 470306d
  • cable sleeves 440612.47
  • cable sleeves 4510b12.67
  • twincable sleeves 470418d
  • cable sleeves 440812.47
  • cable sleeves 451330.67
  • twincable sleeves 490714d
  • cable sleeves 440005.47
Page:
  1. Previous
  2. 2
  3. 3
  4. 4
  5. 5
  6. 6
  7. Next
Categories
      • Blind rivets
      • Blind rivet nuts
      • Hollow rivets
      • Tubular rivets
        • form C
        • form D
      • Rivets
    • Spacer
        • Internal thread
        • Internal thread
        • spacers UNC 4-40
        • snap-in
      • Cable clips
        • 1 mounting hole
        • 2 mounting hole
      • Clamping disks
        • Connecting disks
        • Clamping disks
        • Clamping straps
        • Clamping straps
        • Fastening angle
      • ornamental head
        • For hole < 1.3mm
        • For hole = 1.3mm
        • For hole > 1.3mm
        • In chain form
        • IDC contacts
      • Contact parts
      • Eyelet tags
      • Fuse holders
        • Diameter 5mm
        • Diameter 6.3mm
        • Diameter 8.5mm
        • Quartz holders
      • Contact caps
      • Wire-Wrap-Pins
        • From Wire
        • From Wire, bent
        • Stamped
      • Headers
        • Single Row
        • Single Row Angled
        • Double Row
        • Headers
        • Angle Pin Headers
      • In bulk
      • Soldering bridges
        • Jumpers for PCB
        • Insulated Jumpers
        • Bridge Connectors
        • Tag Blocks
    • SMD Stampings
        • Collar Sleeves
        • Rolled / Stamped
        • Seamless de tube
        • Special
      • Lamp holders
      • I.C. Sockets
      • Battery terminals
      • Battery contacts
    • Soldering tags
      • In bulk
        • 1 foot
        • 2 feet
        • bent
        • receptacles
        • flat
        • bent
        • receptacles
        • flat
        • bent
        • receptacles
        • grid 5 mm
        • grid 10 mm
        • angled, grid 5 mm
        • tab blocks ABB
        • rolled
        • bent
        • bent
        • tabs
        • Posilock
        • rolled
        • bent
        • screwable
      • housings for tabs
        • Dimension 2.8 mm
        • Dimension 2.8 mm
        • Dimension 6.3 mm
        • special
        • housings
        • plug pins form A
        • plug pins form B
        • plug pins
        • Chainform
    • end-sleeves
      • clips
        • chain
      • cable eyelets
        • F colors
        • D colors
        • F colors stripes
        • D colors stripes
        • F colors chain
        • D colors chain
        • F colors
        • D colors
    • Cable terminals
        • fork
        • ring, 3-way
        • ring 4-way
        • fork PVC
        • fork PA
        • ring form A
        • ring form B
        • fork form A
        • fork form B
        • hook
        • long hole
        • ring
        • fork
        • hook
      • crimp terminals
        • in bulk DIN 46225
      • Tubular terminals
        • flat
        • bent 90°
        • tight plate
      • flat with insul.
      • pin connectors
      • connector in PA
    • Boxes and sets
      • set with tool
      • set without tool
        • set without tool
      • box/set
    • chain
      • F colors chain
      • D colors chain
      • ring PVC
      • Ring PA
      • fork PVC
      • pin round
      • 1-pole 95°
      • 2-pole 95°
      • 4-pole 95°
    • Hand tools
      • Tools for wiring
        • wire stripper
        • tool
        • for blind rivets
        • for cable eyelets
        • for terminals
        • for end ferrules
        • for terminals
      • Manual air press
        • press head
      • Battery device
        • for stripes
      • Shrink apparatus
    • Presses
      • Inserting devices
        • applicator
        • spare parts
        • accessories
      • Riveting tools
        • Inserts
      • Manual presses
        • Manual presses
        • Lever presses
      • Pneumatic presses
        • press
        • tandem cylinder
        • Pneumatic gang
      • Machines
        • stripper-crimper
        • Manual air press
        • press body
        • scanning spot
Shop By Characteristics
Currently Shopping by:
  1. Material/Plating: CuZnSn Remove This Item
Clear All
Shopping Options
Packing option
  1. Loose piece (168)
  2. Reel (7)
Size
  1. 0 (1)
  2. 2.8 (23)
  3. 4.8 (21)
  4. 6.3 (36)
Receptacle/Tab Connector Brands
  1. Vogt (82)
AWG
  1. 1/0 (3)
  2. 10 (8)
  3. 12 (6)
  4. 12-10 (3)
  5. 14 (9)
  6. 16 (10)
  7. 16-14 (6)
  8. 18 (8)
  9. 2 (5)
  10. 2/0 (3)
  11. 20-18 (15)
  12. 22-18 (13)
  13. 22-20 (5)
  14. 26-24 (3)
  15. 4 (3)
  16. 4/0 (1)
  17. 6 (5)
  18. 8 (8)
mm2
  1. 0.1 (3)
  2. 0.5 (5)
  3. 0.5-1 (13)
  4. 0.75 (15)
  5. 1 (8)
  6. 1.5 (10)
  7. 1.5-2.5 (6)
  8. 10 (8)
  9. 120 (1)
  10. 16 (5)
  11. 2.5 (9)
  12. 25 (3)
  13. 35 (5)
  14. 4 (6)
  15. 4-6 (3)
  16. 50 (3)
  17. 6 (8)
  18. 70 (3)
  19. 95 (1)
Isolated/Unisolated
  1. Isolated (29)
  2. Unisolated (64)
EndSleeve Brands
  1. Vogt (93)
Estonia
Phone: + 372 671 22 51
Fax: + 372 671 22 53
E-mail
info@gammeter.ee
Parent Company
Gammeter OÜ
Paldiski mnt 31/1
76606 Keila
Estonia
Sweden
Phone: +46 (0)8-445 36 00
Fax: +46 (0)8-445 36 10
E-mail
info@adcontact.se
Sales office
Adcontact AB
Ursviksvägen 127A
SE-174 46 Sundbyberg
Sweden
Finland
Phone: +358 3 380 22 11
Fax: +358 3 380 22 44
E-mail
info@gammeter.fi
Sales office
Gammeter OÜ
Vehnämyllynkatu 6
FIN-33560 Tammerfors
Finland
Norway
Phone: +47 224 177 00
Fax: +47 224 177 01
E-mail
info@adcontact.se
Sales office
Adcontact AB
Postboks 246 Skøyen
NO-0213 Oslo
Norway
Terms of delivery Shipping information Payment information
© 2019 Adcontact – Webbshop av Lybe
To top
